Please refer to the following table for compatibility of Ronin Series accessories:
💡[Tips] √ means adapted, × means not adapted, and “※” means there are some restrictions on use.
Ecological Module
Name | DJI RS 5 | DJI RS 4 Mini | DJI RS 4 | DJI RS 4 Pro | DJI RS 3 Mini | DJI RS 3 | DJI RS 3 Pro | DJI RSC 2 | DJI RS 2 | Ronin-SC | Ronin-S | Note |
RS Enhanced Intelligent Tracking Module | √ | √ | √ | √ | × | × | × | × | × | × | × | When using DJI RS 4/DJI RS 4 Pro, RS Intelligent Tracking Module/RS Enhanced Intelligent Tracking Module adapter mount is required; when using the RS Intelligent Tracking Module adapter mount, the shutter cable cannot be connected simultaneously. |
RS Intelligent Tracking Module | √ | √ | √ | √ | × | × | × | × | × | × | × | When using DJI RS 4/DJI RS 4 Pro, RS Intelligent Tracking Module/RS Enhanced Intelligent Tracking Module adapter mount is required; when using the RS Intelligent Tracking Module adapter mount, the shutter cable cannot be connected simultaneously. |
Electronic Briefcase Handle | √ | × | × | × | × | × | × | × | × | × | × | |
DJI SDR Transmission | √ | × | √ | √ | × | × | √ | × | × | × | × | |
Focus Pro Hand Unit | ※ | × | ※ | ※ | × | ※ | ※ | × | × | × | × | 1. The DJI Focus Pro Hand Unit can only be used with the DJI Focus Pro Motor via linking, and does not communicate with the stabilizer. |
Focus Pro Grip | × | × | × | × | × | × | × | × | × | × | × | |
Focus Pro Motor | √ | × | √ | √ | × | √ | √ | √ | √ | × | × | When using DJI RS 3/RS 3 Pro/RSC 2/RS 2, the Focus Pro Motor Mount Module and 15 mm rod are required. |
Focus Pro LiDAR | × | × | × | √ | × | × | √ | × | × | × | × | |
Ronin Focus Wheel | √ | × | √ | √ | × | × | √ | × | √ | √ | √ | DJI RS 3 Pro with firmware updated to V01.00.01.00 or later supports controlling the focus motor with the DJI R Focus Wheel 2022. |
Ronin RavenEye Image Transmission System | × | √ | √ | √ | × | √ | √ | √ | √ | ※ | ※ | Ronin S/SC cannot be directly connected to the DJI Ronin Image Transmitter, and can only be connected to a camera. |
Ronin Expansion Base Kit | × | × | × | √ | × | × | √ | × | √ | × | × | |
DJI RS Tethered Control Handle | √ | × | √ | √ | × | √ | √ | × | √ | × | × | |
Focus Motor (2022) | √ | × | √ | √ | × | √ | √ | √ | √ | × | × | |
LiDAR Range Finder(RS) | × | × | × | √ | × | × | √ | × | × | × | × | |
DJI Transmission | × | × | × | √ | × | × | √ | × | × | × | × | |
Ronin-S External GPS Module | × | × | × | ※ | × | ※ | ※ | × | ※ | × | √ | When using the "Ronin-S External GPS Module" with DJI RS 4 Pro/RS 3 Pro/DJI RS 2, the "DJI R External GPS Module Connection Cable" accessory is required (DJI RS 3 Pro must connect to the focus motor port via USB-C). |
DJI Force Pro | × | × | √ | √ | × | × | √ | × | √ | √ | √ | |
Master Wheels | × | × | × | √ | × | × | √ | × | √ | √ | √ | |
DJI RS 3D Focus System | × | × | × | × | × | √ | √ | × | √ | × | × | Supported after upgrading DJI RS 3/DJI RS 3 PRO to V01.03.00.00 or later. |
DJI Pro Wireless Receiver | × | × | √ | √ | × | × | √ | × | √ | √ | √ | |
DJI Ronin Focus Motor | ※ | × | ※ | ※ | × | ※ | ※ | √ | √ | √ | × | When using on DJI RS 3, RS 3 Pro, RS 2, or RSC 2, connect it to the gimbal to refresh the firmware; |
Battery
BG33 Battery Grip | √ | × | √ | √ | × | √ | √ | × | √ | × | × |
DJI RS BG70 High-Capacity Battery Grip | √ | × | √ | √ | × | √ | √ | × | √ | × | × |
Ronin BG30 Grip | √ | × | √ | √ | × | √ | √ | × | √ | × | × |
BG21 Grip | × | × | √ | × | × | √ | × | × | × | × | × |
Cable
L-Shaped Cable (USB-C, 13 cm) | √ | × | × | × | × | × | × | × | × | × | × |
DJI Focus Pro LiDAR to DJI Transmission Cable Hub | × | × | × | √ | × | × | √ | × | × | × | × |
Ronin Multi-Camera Control Cable (USB-C) | √ | √ | √ | √ | √ | √ | √ | √ | √ | × | × |
Ronin Multi-Camera Control Cable (Sony Multi) | × | × | √ | √ | √ | √ | √ | √ | √ | × | × |
Ronin Multi-Camera Control Cable (Micro-USB) | √ | √ | √ | √ | √ | √ | √ | √ | √ | × | × |
Ronin Multi-Camera Control Cable (Mini-USB) | √ | √ | √ | √ | √ | √ | √ | √ | √ | × | × |
Ronin RSS Control Cable for Fujifilm | × | × | √ | √ | √ | √ | √ | √ | √ | × | × |
Ronin RSS Control Cable for Panasonic | × | × | √ | √ | √ | √ | √ | √ | √ | × | × |
Ronin Mini-HDMI to HDMI Cable (20 cm) | × | × | √ | √ | × | √ | √ | √ | √ | √ | √ |
Ronin Mini-HDMI to Mini-HDMI Cable (20 cm) | × | × | √ | √ | × | √ | √ | √ | √ | √ | √ |
Ronin Mini-HDMI to Micro-HDMI Cable (20 cm) | × | × | √ | √ | × | √ | √ | √ | √ | √ | √ |
DJI R External GPS Module Adapter Cable | × | × | √ | √ | × | √ | √ | × | √ | × | × | Not supported on vehicles. |
Structural Part
RS 5 Upper Quick-Release Plate | √ | × | √ | √ | × | √ | √ | √ | √ | × | × |
RS 5 Lower Quick-Release Plate | √ | × | √ | × | × | √ | × | √ | × | × | × |
Quick-Open Tripod | √ | √ | √ | √ | √ | √ | √ | √ | √ | √ | √ |
Quick-Release Plate | × | √ | × | × | × | × | × | × | × | × | × |
RS 4 Mini Tripod | × | √ | × | × | √ | × | × | × | × | × | × |
RS 4 Mini Briefcase Handle | × | √ | × | × | × | × | × | × | × | × | × |
RS 4 Mini Phone Holder | × | √ | × | × | × | × | × | × | × | × | × |
DJI RS Upper Quick-Release Plate (2024) | ※ | × | √ | √ | × | √ | √ | √ | √ | × | × | DJI RS 5 can be mounted, but it affects balancing under extreme operating conditions. |
DJI RS Pro Lower Quick-Release Plate (2024) | ※ | × | √ | √ | × | √ | √ | √ | √ | × | × | DJI RS 5 can be mounted, but it affects balancing under extreme operating conditions. |
DJI RS Lower Quick-Release Plate (2024) | ※ | × | √ | √ | × | √ | × | √ | × | × | × | DJI RS 5 can be mounted, but it affects balancing under extreme operating conditions. |
Focus Pro Motor Rod Mount Kit | √ | × | √ | √ | × | √ | √ | √ | √ | × | × | When using DJI RS 3/RS 3 Pro/RSC 2/RS 2, the DJI Focus Pro Motor must be used together. |
Ronin Extended Grip/Tripod (Metal) | √ | √ | √ | √ | √ | √ | √ | √ | √ | √ | √ | Original accessory name: "DJI R Extended Grip/Tripod (Metal)" |
Ronin Cheese Plate | √ | √ | √ | √ | √ | √ | √ | √ | √ | √ | √ |
Ronin Focus Gear Strip | √ | √ | √ | √ | × | √ | √ | √ | √ | √ | √ |
Ronin Phone Holder | √ | √ | √ | √ | √ | √ | √ | √ | √ | ※ | ※ | 1. Only supports attaching to the camera hot shoe; |
Ronin Twist Grip Dual Handle | √ | ※ | √ | √ | ※ | √ | √ | √ | √ | × | ※ | Ronin-S: Requires the quick-release port middle frame of the dual-handle combo |
Ronin Vertical Camera Mount | × | × | × | × | × | √ | √ | × | √ | × | × |
Ronin Screw Kit | √ | × | √ | √ | × | √ | √ | √ | √ | × | × |
Ronin Quick-Release Plate (Lower) | √ | × | √ | √ | × | √ | √ | √ | √ | × | × |
Ronin Quick-Release Plate (Upper) | √ | × | √ | √ | × | √ | √ | √ | √ | × | × |
Ronin Lens-Fastening Strap | √ | × | √ | √ | × | √ | √ | √ | √ | √ | √ |
Briefcase Handle | √ | √ | √ | √ | √ | √ | √ | √ | √ | × | ※ | Ronin-S: Requires the quick-release port middle frame of the dual-handle combo |
Lens Support | √ | × | √ | √ | × | √ | √ | √ | √ | √ | √ |
Lens Support (Extended) | √ | × | √ | √ | × | √ | √ | √ | √ | √ | √ |
Ronin-S/SC Phone Holder | ※ | × | ※ | ※ | × | ※ | ※ | ※ | ※ | √ | √ | Supports using on DJI RS 3/RS 3 Pro/RS 2/RSC 2, but DJI R Phone Holder is more recommended. |
DJI R Roll Axis Counterweight Set | × | × | √ | × | × | √ | × | √ | √ | × | × | When using it with DJI RS 3, if the Tilt Motor Clamp cannot be installed, please use an Allen wrench (4 mm or smaller size) to properly loosen the lock knob and thus increase the clamping length, and then complete the installation. |
Lower Quick-Release Plate (Extended) | ※ | × | ※ | √ | × | ※ | √ | ※ | √ | × | × |
DJI RS 5 Carrying Case | √ | √ | √ | √ | ※ | √ | √ | ※ | ※ | ※ | × |
DJI RS 3/RS 3 Pro Carrying Case | √ | √ | √ | √ | ※ | √ | √ | ※ | ※ | ※ | × |
DJI R Briefcase Handle | √ | × | √ | √ | √ | √ | √ | √ | √ | × | × |
DJI RS 3 Mini Upper Quick-Release Plate/DJI RS Mini Quick-Release Plate | × | × | × | × | √ | × | × | × | × | × | × |
DJI RS 3 Mini Lower Quick-Release Plate | × | × | × | × | √ | × | × | × | × | × | × |
Ronin-S/Ronin-SC related accessories compatibility
Ronin-S BG37 Grip | × | × | × | × | × | × | × | × | × | × | √ |
Ronin-S/SC Command Unit | × | × | × | × | × | × | × | × | × | √ | √ |
Ronin-S Top Hotshoe Bracket | × | × | × | × | × | × | × | × | × | × | √ |
Ronin-S/SC Extended Lens Support | × | × | × | × | × | √ | √ | √ | √ | √ | √ |
Ronin-S Camera Mounting Plate | × | × | × | × | × | × | × | × | × | × | √ |
Ronin-S Focus Motor | × | × | × | × | × | × | × | × | × | × | √ | Ronin-S Focus Motor can only be used with Ronin-S. |
Ronin-S Focus Motor Rod Mount | × | × | × | × | × | × | × | × | × | × | √ |
Ronin-S Universal Mount | × | × | × | × | × | × | × | × | × | × | √ |
Ronin-S Battery Adapter | × | × | × | × | × | × | × | × | × | × | √ |
Ronin-S DC Power Cable | × | × | × | × | × | × | × | × | × | × | √ |
Ronin-S Camera Riser | × | × | × | × | × | ※ | ※ | ※ | ※ | √ | √ | DJI RS 3/RS 3 Pro/RS 2/Recommended Service Center 2 can be used, but it is not necessary. |
Ronin Series Multi Tool | √ | × | √ | √ | × | √ | √ | √ | √ | √ | √ |
Ronin-MX CAN Cable for Ronin-MX/S | × | × | × | √ | × | × | √ | × | √ | √ | √ |
Ronin-S Multi-Camera Control Cable (IR/Multi/Type-C/Type-B/RSS-P) | × | × | × | × | × | × | × | × | × | × | √ |
Ronin-SC BG18 Grip | × | × | × | × | × | × | × | × | × | √ | × |
Ronin-SC Focus Motor | × | × | × | × | × | √ | √ | √ | √ | √ | × | When using on DJI RS 3, RS 3 Pro, RS 2, or RSC 2, connect it to the gimbal to refresh the firmware. |
Ronin-SC Multi-Camera Control Cable (Multi/Type-C) | × | × | × | × | × | × | × | × | × | √ | × |
Ronin-SC Multi-Camera Control Adapter (Type-C to Micro-USB) | × | × | × | × | × | × | × | × | × | √ | × |
Ronin-SC RSS Splitter | × | × | × | × | × | × | × | × | × | √ | × |
Ronin-SC L-Bracket Plate | × | × | × | × | × | × | × | × | × | √ | × |
Ronin S/SC Handgrip Mount | ※ | × | ※ | ※ | × | ※ | ※ | ※ | ※ | √ | √ | Supports using on DJI RS 3, RS 3 Pro, RS 2, and RSC 2, but can only be used with the parts designed with a lock knob. Therefore, the use experience is not good. It is recommended to use DJI R Briefcase Handle. |
Ronin-S/SC L-Bracket Plate with Counterweight | × | × | × | × | × | ※ | ※ | ※ | ※ | √ | √ |
Ronin-S/SC Adjustable Monitor Mount | ※ | × | ※ | ※ | × | ※ | ※ | ※ | ※ | √ | √ | DJI RS 3/RS 3 Pro/RS 2/RSC 2 can be used and can be mounted to the 1/4'' threaded port at the end of the DJI RS Briefcase Handle; RS 5 can be mounted to the 1/4'' threaded port on the Handgrip Handle. |
DJI RS 2/RSC 2 Carrying Case | ※ | × | ※ | ※ | ※ | ※ | ※ | √ | √ | ※ | × |
Ronin-SC Storage Case | × | × | × | × | × | × | × | × | × | √ | × |
Ronin-S Storage Case | × | × | × | × | × | × | × | × | × | × | √ |
Tips:
If you are reading this article on a computer, feel free to utilize the "Ctrl+F" function to easily search for the specific accessory or stabilizer you wish to inquire about.
