DJI AP100 Parachute is the first parachute from DJI Enterprise. It is designed for Matrice 400 and supports compliance with EU C5/C6 and UK UK5/UK6 operational requirements.
Weighing about 935 g, it is rated IP55 and features independent power and a full-link redundant design. It supports both manual and automatic deployment and can complete motor stop and parachute deployment within 600 ms, it helps protect your platform, payloads, and the ground below.
Compatible with DJI Matrice 400 and supports C5/C6 compliance.
Supported Regions
Available worldwide
Note
Geocaging is supported in the following countries and regions: EU member states (Austria, Belgium, Bulgaria, Croatia, Cyprus, Czechia, Denmark, Estonia, Finland, France, Germany, Greece, Hungary, Ireland, Italy, Latvia, Lithuania, Luxembourg, Malta, Netherlands, Poland, Portugal, Romania, Slovakia, Slovenia, Spain, Sweden), the United Kingdom, Norway, Iceland, Switzerland, Liechtenstein, Serbia, and Georgia.
Installation and Use
For details, please refer to the official tutorial video:https://enterprise.dji.com/ap100-parachute/video
DJI AP100 can remain attached when placed in the DJI Matrice 400 carrying case, so it only needs to be installed once for ongoing use.
Key Specifications
Stabilized Descent Speed after Deployment: ≤ 5 m/s
Ingress Protection Rating: IP55 (same as DJI Matrice 400)
Max Takeoff Weight: 15.8 kg (DJI Matrice 400 with the parachute installed)
Device Weight: Approx. 935 g
Automatic Deployment Response Time: ≤ 600 ms
No Automatic Deployment Near the Ground
To mitigate the risk of damage to nearby equipment or property caused by close-range deployment, the automatic deployment will be disabled under either of the following conditions:
1.  The aircraft is within a 10 m radius of the Home Point, and its relative altitude is within 15 m above or below the Home Point.
2.  With Cleaning Mode enabled, the aircraft is within a 10 m radius of the Home Point, and its relative altitude is within 15 m above the Home Point.
