Purpose
· The purpose of this document is to show users how to repair the DJI product, and list common issues and their solutions, but for complex exceptions or error messages, it is recommended to contact DJI Support for assistance.
· To find the related product features and usage information, please visit the DJI’s official website at http://www.dji.com/.
Notices
· Keep the product and other modules away from children.
· Do not let the product come into contact with liquid or water.
· Do not power on the product immediately after it has fallen into water.
· Do not store the product in a humid area.
Battery Safety Notices
· Do not allow a battery to come into contact with any kind of liquid, or leave it out in the water.
· Do not use swollen, leaking, or damaged batteries.
· Do not install or remove a battery when it is turned on.
· Use a battery at temperatures from -10℃ to 40℃.
· Do not use batteries in strong electrostatic or electromagnetic environments.
· Do not disassemble or pierce batteries in any way.
· Do not place wires or metal objects on a battery. Otherwise, the battery may short-circuit.
· Do not drop or strike a battery, or place heavy objects on the battery.
· Electrolytes in batteries are highly corrosive. In the event of a leakage, please stay away from the battery.
· Keep batteries out of the reach of children.
· Do not leave batteries near heat sources.
· Keep batteries dry.
· Keep batteries away from the metal objects, such as glasses, watches, or necklace during transportation or storage.
· Do not transport a damaged battery.
· Do not store batteries in environments with a temperature higher than 45℃ or lower than 0℃.
· Do not place batteries in regular trash containers.
Applicable Models
No.
Model
No.
Model
Phantom 4 Pro V2.0
21
DJI Air 3
Mavic 3
22
Mavic Mini
Mavic 3 Cine
23
Mavic 2 Pro
4
Mavic 3 Classic
24
Mavic 2 Zoom
5
Mavic 3 Pro
25
Mavic Air
6
Mavic 3 Pro Cine
26
Mavic Pro Alpine White
7
DJI Air 2S
27
Mavic Pro Platinum
8
Mavic Air 2
28
Mavic Pro
9
DJI Mini 3 Pro
29
DJI RC Pro 2
10
DJI Mini 3
30
DJI RC-N1C
11
DJI Mini 2
31
DJI RC-N2
12
DJI Mini 2 SE
32
DJI RC 2
13
DJI Mini SE
33
Phantom 4 Pro+
14
DJI RC
34
Phantom 4 Advanced+
15
DJI RC Pro
35
Phantom 4 Pro V2.0
16
DJI Mini 5 Pro
36
Phantom 4 Pro
17
DJI Mavic 4 Pro
37
Phantom 3 Standard
18
DJI Air 3S
38
Phantom 3 4K
19
DJI Mini 4K
39
Phantom 3 SE
20
DJI Mini 4 Pro
40
Phantom 3 Advanced
41
Phantom 3 Professional
Aircraft
Common Issue
Inspection Method
Repair Method
Aircraft arm broken or skewed
Perform visual inspection and check if the aircraft arm is cracked and cannot be used normally.
Replace the aircraft.
Upper cover cracked or misshapen
Perform visual inspection and check if the upper cover is obviously cracked or misshapen, or if there are any other cosmetic damages.
Gimbal axis arm broken
Perform visual inspection and check if the gimbal axis arm is obviously cracked or misshapen, or if there are any other cosmetic damages.
Abnormal camera image
Enter the camera view in the app and check if the image is displayed abnormally, such as blurry image, stripes, and noises.
Gimbal stabilization error
Enter the camera view in the app and check if the image is skewed or shaking.
Propulsion system error
Turn on the motors and check if the motors are spinning correctly.
Camera sensor error
Check if the app prompts a “Camera Sensor Error” warning.
App prompts GPS disconnected warning
Check if the app prompts a “GPS disconnected” warning.
Remote Controller
Common Issue
Inspection Method
Repair Method
Upper shell cracked or misshapen
Perform visual inspection and check if the upper shell is obviously cracked or misshapen, or if there are any other cosmetic damages.
Replace the remote controller.
Lower shell cracked or misshapen
Perform visual inspection and check if the lower shell is obviously cracked or misshapen, or if there are any other cosmetic damages.
Control sticks not re-center
Check if the drone response corresponds to the control stick input.
Use the app to calibrate the remote controller. If the issue persists, replace the remote controller.
Power-on failure
Check if the remote controller can be powered on after charging.
Remote controller GPS error
Check if the app prompts a “Remote Controller GPS Error” warning.
Abnormal screen display
Perform visual inspection and check if the screen is black out or freezes, and if the screen is not displayed completely.
Replace the remote controller (with a built-in screen).
Battery and Charger
Common Issue
Inspection Method
Repair Method
Battery/charger outer shell cracked or misshapen
Perform visual inspection and check if there are any other cosmetic damages such as cracked and misshapen that may affect the normal use.
Replace the corresponding defective module.
Battery charging error
Use a functioning normally battery charging hub to charge the battery and see if it can be charged.
Discharging error
Install the battery to the drone and check if the drone can be powered on.
Cable
Common Issue
Inspection Method
Repair Method
Cable damaged
Perform visual inspection and check if the cable is damaged.
Replace the cable.
Unable to connect the mobile phone
Replace the cable and check if the connection is normal.
Replace the cable.
Other Accessories
Perform visual inspection and check if accessories are cracked or there is structural damage. Then replace the corresponding accessory.
