Issue Descriptions
The display of the DJI Power indicates "ERR70", and the DJI Home app prompts "USB-A output error".
Solution
1. Remove the connected device from the USB-A port.
2. Power off the power station by pressing and holding the power button. Then press and hold the button again to power it on after 30 seconds.
3. Cross-test with other USB-C appliances to check if they work properly. If they do, the current appliance may be faulty or incompatible with the power station.
4. If the above solution does not resolve your issue, please contact DJI Support.
