DJI Avata 360
Function Introduction
You can easily control the aircraft or the camera view to perform flips, 180° drifts, lateral movements, and Juicy Flick using the traverse joysticks.
Operating Path
1.Open the quick settings panel in the flight interface and select the "Fancy Flight" option. The aircraft enters the Trick Flight mode, and the selected maneuver can be viewed on the left side of the flight interface.
2. Use the dial on the side of the FPV joystick to switch between various flight maneuvers.
3.Use the joystick to control the aircraft to perform various aerial maneuvers. The specific control methods are as follows.
Slide:
Push the joystick up or down to make DJI Neo ascend or descend.
Push the joystick left or right to make DJI Neo move left or right horizontally.
180° Drift:
Move the joystick to the left or right once, and the aircraft will drift left or right once, achieving a 180° drifting effect.
DJI Neo will not respond when pushing the joystick up or down in this action mode.
Flip:
Push the control stick up or down once, and the aircraft will not flip; instead, the footage will show a forward or backward flip effect.
Push the joystick once to the left or right, the aircraft does not flip, but the image shows the effect of flipping once to the left or right.
Juicy Flick:
Push the stick up once and the aircraft will rotate, resulting in a dynamic rolling effect in the footage.
Precautions for Use:
① In the following situations, the Trick Flight feature cannot be used:
◆ The aircraft is in the process of taking off, braking and hovering, landing, or returning to home;
◆ The current positioning performance of the aircraft is poor (no satellite positioning or vision positioning);
◆ The aircraft is in a no-fly zone, altitude limit, or the buffer zone at the edge of the maximum flight range.
Zoom is not available during Fancy Flight; the field of view will remain as it was when Fancy Flight was enabled.
② In the following situations, the Fancy Flight feature cannot be activated:
◆ During video recording.
◆ When head tracking is enabled.
◆ When Focus Follow is enabled.
◆ When using the DJI FPV Remote Controller 3 to operate the aircraft.
DJI Avata 2
You can use DJI RC Motion 3 for easy control of DJI Avata 2 for front and back flips, left and right rolls, and 180° drifts. This will contribute to a unique, exhilarating control experience.
Operating Path
Toggle the 5D button down to open the shortcut menu and select Easy ACRO. Then, the drone enters the Easy ACRO mode.
Easy ACRO actions include Slide, 180° Drift, and Flip.
When used with DJI Goggles N3/DJI Goggles 3 and DJI FPV Remote Controller 3, the one-tap Big Loop feature is newly supported. This feature is not supported when paired with other goggles and remote controllers.
You can view the selected action on the left side of the liveview. Toggle the dial on the motion controller to switch between Easy ACRO actions. Toggle the joystick on the motion controller to perform Easy ACRO actions.
💡[Tips]
* Easy ACRO is available only in N mode. For details about the precautions for using Easy ACRO, see the "Easy ACRO" section in the DJI Avata 2 User Manual.
* The Easy ACRO on DJI Store app Virtual Flight only supports flips and rolls, and does not support 180° drift.
* DJI Avata 2 can't use the Easy ACRO when recording video, you need to activate Easy ACRO first, and then open the video recording.
* DJI Avata 2 does not support the adjustment of flight speed, flight radius, and flight distance.
* When used with an FPV remote controller, Easy ACRO is not supported.
