Connecting to a Mobile Device
Insert the included mobile phone adapter into the bottom of the receiver, then connect the receiver to a mobile device via pogo-pin port. Start video or audio recording on the mobile device.
Connecting to a Camera
DJI Mic Mini 2:Mount the receiver on your camera’s cold shoe or hot shoe, then connect it to the mic input using a camera cable. The transmitter will transmit audio directly to your camera.
DJI Mic Mini :Mount the receiver on your camera’s cold shoe or hot shoe, then connect it to the mic input using a camera cable. The transmitter will transmit audio directly to your camera.
DJI Mic 3: Mount the receiver on your camera’s cold shoe or hot shoe, then connect it to the mic input using a camera cable. The transmitter will transmit audio directly to your camera.
DJI Mic 2: Mount the receiver on your camera’s cold shoe or hot shoe, then connect it to the mic input using a camera cable. The transmitter will transmit audio directly to your camera.
DJI Mic: Mount the receiver on your camera’s hot shoe through the hot shoe adapter, then connect the 3.5mm audio output port to the camera mic input using a 3.5mm camera audio cable. Start recording video on your camera, and the transmitter will transmit audio directly to the camera.
Connecting to a Computer
1. Connect the receiver to the computer using the included charging cable.
💡 Note: The computer should detect the device automatically. If not, set your computer’s microphone input to “Wireless Microphone RX”.
2. Connect the receiver to the computer using the phone adapter (USB-C). (The computer should support Type-C audio input).
3. If the computer has separate microphone and headphone jacks, connect the receiver’s output port to the computer’s microphone input using a 3.5mm audio cable.
💡 Note: The computer should detect the device automatically. If not, set the audio input to the microphone jack in sound card settings. The actual steps may vary depending on the computer.
4. If the computer has only one 3.5mm combo jack, connect a 3.5mm splitter to the computer (to separate mic and headphone connections), then use a 3.5mm audio cable to connect the receiver’s output port to the mic input on the splitter.
💡 Note: The computer should detect the device automatically. If not, set the audio input to the microphone jack in sound card settings. The exact steps may vary depending on the computer.
📖 Learn More: What should I do if DJI Mic cannot be identified or fails to record an audio when connected to a mobile phone?
