[Notice] DJI Virtual Flight Maintenance Discontinuation Notice
DJI Virtual Flight is DJI's first FPV simulator that provides an immersive flight experience wherever you go. DJI Virtual Flight is currently available on iOS, Android, and Windows.
Supported devices: DJI Goggles Integra, DJI Goggles 2, DJI FPV Goggles V2, DJI Motion Controller, DJI FPV, and DJI FPV Remote Controller 2.
• DJI Avata 2, DJI Goggles 3, DJI Motion Controller 3, and DJI Motion Controller 2 do not support Virtual Flight.
• DJI Goggles are not compatible with the Windows version of the Virtual Flight software.
• DJI FPV Remote Controller 3 is not supported by DJI Virtual Flight. Please use third-party flight simulators such as Liftoff, Uncrashed, The Drone Racing League (DRL), or The Drone Champions League (DCL) for practice.
Usage Method
iOS
Follow the instructions below:
1. Connect DJI FPV Goggles V2 or DJI Goggles 2 to DJI FPV Remote Controller 2 or DJI Motion Controller.
2. Directly use DJI Virtual Flight on your mobile phone without any connection operations.
Android
2. Directly use DJI Virtual Flight on DJI FPV Remote Controller 2.
3. Directly use DJI Virtual Flight on your mobile phone or DJI RC Pro without any connection operations. (Choose Control > Confirm to enable touchscreen control.)
Windows
1. Use a Type-C cable to connect DJI Motion Controller or DJI FPV Remote Controller 2 to your computer.
2. DJI Virtual Flight on Windows supports using with DJI FPV Remote Controller 2 and DJI Motion Controller, but does not support DJI Goggles 2 and DJI FPV Goggles V2.
Ensure that the connected devices have been sufficiently charged and activated. Make sure that the goggles, remote controller, and motion controller firmware and the DJI Virtual Flight app have been updated to their latest versions.
How do I download the software?
The app is available on iOS and Android, with the following devices supported: DJI FPV, DJI Avata. Click here to download: DJI Virtual Flight
If you are using the DJI RC Pro, please click here to download and install the DJI Virtual Flight.
DJI Virtual Flight is also available as a desktop app on Windows. Click here to download: DJI Virtual Flight Desktop Version
How do I link with goggles and DJI RC Motion 2?
DJI Mavic 3 series drones (including DJI Mavic 3, DJI Mavic 3 Classic, and DJI Mavic 3 Pro) and DJI Mini 3 Pro can be used together with DJI Goggles Integra (or DJI Goggles 2) and DJI RC Motion 2 after linking.
Refer to the video below for guidance on how to link and use the devices:
What should I do if I cannot connect a device to DJI Virtual Flight?
Follow the troubleshooting steps below:
1. Ensure that the connected devices have been sufficiently charged and activated. Make sure that the goggles, remote controller, and motion controller firmware and the DJI Virtual Flight app have been updated to their latest versions.
2. If you use DJI Goggles 2, choose Menu > More > DJI Virtual Flight and enable virtual flight. This step is not required if you use DJI FPV Goggles V2.
3. Connect the goggles to your mobile phone by using an OTG cable plus a USB data cable, USB-C to USB-C data cable, or USB-C to Lightning data cable. Ensure that the cables used are the OTG cable and data cable that included in the combo.
If you use an Android mobile phone, follow the steps below to complete the required settings:
1. When you connect the goggles to your mobile phone, Transfer photos, Transfer files, and Charging only are displayed (for some Android devices), then select Transfer files.
2. Check whether DJI Fly or another app that supports AOA communication is launched when you connect the goggles.
If yes, tap Settings on your phone, choose Applications > Application manager, find and tap DJI Fly (or the app launched upon connection), tap Set as default, and then tap CLEAR DEFAULTS to clear the default setting. Connect the goggles again. When a prompt pops up, select DJI Virtual Flight instead of DJI Fly or any other app and check whether the goggles can be connected successfully
