MG-1, MG-1S, MG-1S RTK
No filter attached
MG-1S Advanced
The filter at the tank inlet is 50 mesh, while the filters at the bottom water outlet of the spray tank are 50 mesh + 100 mesh (two overlapping filters).
MG-1P & MG-1P RTK
T16 & T20
T30 & T10
The filter at the tank inlet is 50 mesh, while the filter at the bottom water outlet of the spray tank is 100 mesh.
T40 & T20P
T50 & T25
The filter at the tank inlet is 50 mesh, while the filters at the bottom water outlet of the spray tank are 30.
T60 & T25P
The filter at the tank inlet is 50 mesh, while the filter at the bottom water outlet of the spray tank is 50 mesh.
T70 & T70P & T100 & T100S & T70S & T55
Mesh number: The mesh number indicates the number of holes per unit area. The higher the mesh number, the more holes there are, leading to finer filtration for the same area.
