Osmo Nano
For first-time use, the camera should be activated in the DJI Mimo app. Download the app here.
Enable Wi-Fi and Bluetooth on the mobile device. Open the DJI Mimo app, tap the camera icon on the home screen, and follow the prompts to connect and activate the camera.
Osmo 360
The camera needs to be activated via DJI Mimo when it is used for the first time. Click here to download the app.
Enable Wi-Fi and Bluetooth on the mobile device. Open the DJI Mimo app and follow the on-screen instructions to connect and activate the camera.
Osmo Mobile Series
Before Osmo Mobile 8P,Osmo Mobile 8, Osmo Mobile 7P, Osmo Mobile 7, Osmo Mobile 6, Osmo Mobile SE, Osmo Mobile 5, Osmo Mobile 4, and Osmo Mobile 4 SE are activated, they can be used as stabilizers. Since it is unable to use DJI Mimo app for gimbal self-check, problems such as gimbal spinning and jitter may occur. To ensure the normal use of the Osmo Mobile series product, it is recommended that you activate it before use.
Osmo Action Series
After an Osmo Action series camera is powered on, the display screen prompts " Scan the QR code to download DJI Mimo and connect to camera unit to activate ", and "Skip (remaining times: 5)" is displayed underneath.
The number of times that you can use the Osmo Action series product without activation is reduced by one each time you power on and then power off the camera. After five trials, you need to connect to the DJI Mimo app for activation before use.
Osmo Pocket Series
Osmo Pocket 4 Series& Osmo Pocket 3
Osmo Pocket 4P/Osmo Pocket 4/Osmo Pocket 3 requires activation through the DJI Mimo App. Click here to download it. DJI Mimo App
Connecting Osmo Pocket 4P/Osmo Pocket 4/Osmo Pocket 3 to a Mobile Phone for Activation
1. Press the Shutter button briefly, or rotate the screen to activate the camera.
2. Enable Wi-Fi and Bluetooth on the mobile device.
3. After launching the DJI Mimo app, tap on the camera icon on the home page to connect the camera. Follow the on-screen instructions for further steps.
Tips: Osmo Pocket 4P cannot connect to both the DJI Mimo app and the Osmo FrameTap at the same time (only one connection is supported). If activation of the camera is required, please ensure the remote controller is powered off and then activate the camera via the DJI Mimo app.
Refer to this video for the activation steps.
DJI Pocket 2 & Osmo Pocket
When using a DJI Pocket 2 & Osmo Pocket for the first time, you need to power it on, connect it to a mobile device through a smartphone adapter, and download the DJI Mimo app in the mobile device to activate the product before use.
The activation steps are from 02:45 to 03:22 in the video
